Mr_Mark1
Jul 11, 2013Explorer
SpurHntr wrote:
Can ANYONE see the pic I posted above?
Looks ok on my screen.
To the OP
I believe all you have to do is go to
My Forums
My Preferences
Then under General just make sure the box to "show images" is checked
Yes, I can see your picture just fine and it sure brought back memories when we went through Tea, SD, 4-5 yrs. ago. We stopped at a campground with a similar ground composition. It had rained the day before so our spot appeared a little soft. We actually had a little more gravel than you.
I noticed the next morning that my steps were a bit lower to the ground than I remember before going to bed. We sank an inch or two overnight. So, the next morning, I was concerned about getting out as we were angled at a slight upgrade to pull out. Well, my drive wheels just started to spin. I rolled back (with towed attached) and it would roll about three feet and start spinning again.
So, I thought... I'll put my co-pilot in the Honda with walkie-talkie's in hand. I'll give the go-ahead to hit the gas when I hit the diesel pedal. It was enough momentum to get us rolling. Our Honda saved the day!!!
Do you think that would have worked in your situation? Our little AWD Honda had just enough umpth to push a 40,000 lb. coach! LOL!
MM.
38,766 PostsLatest Activity: Jan 10, 2026
