Fatnjoe12ExplorerJun 30, 2016ADVICE PLEASEI took a 91 fleetwood Coronado on a trade. It has been sitting not running for 2.5 yrs. I had to change the fuel pump and clean tank and now it runs good. Few problems: first Is I can't get the interi...Show More
gboppExplorerJul 01, 2016Get your batteries working before you try to figure out anything else.If they're dead or weak, you can't diagnosis the other problems.Start with making sure the terminals are clean and tight. Then see if they will take and hold a charge.I have a 96 Southwind and if the terminals get a little corrosion (even if they look clean) it will cause electrical problems.This may help you understand your electric system, The 12 Volt Side of Life.Keep us updated on your progress.
Related ContentAdvice pleaseTOAD setup advice pleaseAdvice pleaseNeed hitch advice please.More Advice, please.
