Daveinet
Sep 20, 2013Explorer
Time for a reality check. The resistance at normal operating temp (200 degrees) is around 1K ohms. 18 gauge wire resistance per foot is around .5 ohms per 100 FEET ! A 10 degree difference is a about 100 ohms change. A poor connection could cause the problem, but not the wire gauge.
I should also ad that you could see some difference as a result of where the 2 sensors are mounted. Otherwise, I would suggest the sensor is probably off.
38,766 PostsLatest Activity: Jan 10, 2026
