eastfizz
Sep 22, 2013Explorer II
I do not know what your altitude is, or how you are testing the gauge, however when I was testing a trans fluid temperature gauge with boiling water, it was reading about 200 degrees F when the water boiled. I thought the gauge might be bad or the wire was not large enough for the run to the trans from the gauge. After some checking, I determined the gauge was correct as water boils at about 200 degrees F at my altitude, 7100 ft. Hope this is helpful.
Best regards,
Lowell
Best regards,
Lowell
38,766 PostsLatest Activity: Jan 10, 2026
