pianotuna
Sep 11, 2022Nomad III
garmp wrote:
My coach has a switch to disconnect the coach battery. Would that be sufficient enough rather than manually unbolting the batteries?
If you never cold weather camp, then LiFePo4 are a similar price to AGM. They can be stored for a long time with no charging--and in fact it is best to store them at 50% state of charge.
The other solution is a small solar charging system.
The disconnect switch may not eliminate all parasitic loads. Best to disconnect the negative post.
38,780 PostsLatest Activity: Aug 05, 2026
