bgum
Sep 11, 2022Explorer
As stated by several people above disconnect a wire from the battery. An AGM will need charging after about 4 weeks or so even if you disconnect a wire. I suggest you disconnect a wire and put 10 watt maintainers on each battery. A disconnect switch is not adequate.
It may be simpler to bring the batteries home with you.
38,780 PostsLatest Activity: Aug 05, 2026
