Grit_dog
Sep 11, 2022Trailblazer
pianotuna wrote:garmp wrote:
My coach has a switch to disconnect the coach battery. Would that be sufficient enough rather than manually unbolting the batteries?
If you never cold weather camp, then LiFePo4 are a similar price to AGM. They can be stored for a long time with no charging--and in fact it is best to store them at 50% state of charge.
The other solution is a small solar charging system.
The disconnect switch may not eliminate all parasitic loads. Best to disconnect the negative post.
By similar, do you mean the cheapest Li are similar to the most expensive AGM batteries?
If apples to apples are similar, I’m very interested but haven’t seen that.
38,780 PostsLatest Activity: Aug 05, 2026
