SPRING_STREET's avatar
Oct 02, 2018
AGS Coming On By Itself
RV is sitting at home plugged in! Went outside this morning and heard the genny starting up. Went to breaker box to make sure nothing had tripped, all as should be. My setting on the Magnum Energy system was set to enable. Just don't understand why it would come on by itself ? HELPAGS Coming On By Itself
  • My coach was plugged into 50 amp. I had drained all the tanks including the hot water tank as I wouldn’t be traveling for a few months. I shut off the breakers for the refrigerator and the hot water tank. One day I turned on the air conditioner while I was cleaning the coach. The generator immediately came on also even while still being plugged into 50 amp. For a couple days I was googling all over the internet trying to find out why the generator came on. Finally, found the answer. As soon as I turned the hot water heater breaker back on, the generator never started up again on its own while being plugged in. Have no idea why, but that was the solution to my problem
  • Do you have a cat? Does your neighborhood have cats or squirrels or possums?
    If so, jamb a toothpick under the outside start switch.
    Ah Ha. I will bet you have a Intellitec or PCS built in EMS system. Usually, the HW breaker is the 120 power supply breaker to the EMS control board. When you turned that breaker OFF, the system lost its Shore Power signal and then turned on the Genset. Which EMS system do you have? Doug
  • dougrainer wrote:
    KD4UPL wrote:
    dougrainer wrote:
    larry cad wrote:
    The magnum also has a sensor for RV temperature inside. It may be that the inside temp rose too high and the genny came on. The theory is that a temp rise causes the genny to start which starts the A/C if it is turned on.
    Explain which model you are talking about. I know of NO Magnum and its optional AGS module that has an Interior temp sensor connected to it. There are AC systems that a Magnum can COMMUNICATE with to start the Genset when the AC system calls for cool. But, you have to program that and engage the AGS system to be ON. AND, If you are plugged into Shore Power, that disengages the Temp control system from starting the Genset unless you lose Shore Power. Doug
    Every Magnum AGS I've ever seen has an input for a temp sensor. The last one I installed came with the temp sensor in the box. They will work with pretty much every Magnum inverter ever made. I'll not list all the models.
    OK, That is called a BTS Temp sensor. BATTERY TEMP SENSOR. Has nothing to do with the interior AC control system. You attach that sensor to a Coach battery post for Temp monitor charging. If you installed that BTS inside the RV, I suggest you go back and READ the directions. Doug
    PS, maybe more explanation is needed
    1. The Inverter/Charger does NOT have Roof AC AGS connections or capability. It does have a network plug for the optional AGS module
    2. The 2 Magnum separate AGS modules do have the capability to use interior RV temp to start the genset with or without a Magnum Inverter/Charger.
    3. BUT, for this capability, you MUST use the Magnum AGS optional kits.
    4. The Magnum remote panel has the Interior temp sensor in the remote switch. So, it must be installed in a location where it will correctly sense the interior temp of the RV, which most OEM's do NOT install the remote switch where it is best located for interior temp sensing.
    I know the d*** difference between a BTS and a temperature sensor for ambient temperature! Magnum AGS DO have a connection for a temperature sensor. If you will note in the AGS manual section 1.0 describes rising temperature as something that can trigger the generator to start to power an air conditioner. Section 2.4.1 describes the remote temperature sensor cable and where to connect it. Section 4.3.2 describes how the ready LED is solid when the temp sensor is connected and flashes when it is not.
    I guess you never read the manual.
    NO, YOU said MAGNUM, NOT, MAGNUM AGS! That is why I clarified my remarks to make sure we were talking about the MAGNUM AGS. Yes, if you are talking about the Magnum AGS that comes with the remote inside temp sensor, you are correct. You should have clarified your statement to mean when you are working with a Magnum AGS system. Doug
  • It says AGS in the title of the post and it says AGS in the OP's very first post. Your own reply to Larry cad mentions the AGS as well.
    I thought that's what we were talking about the whole time.
    I can't stand it.
    It's not worth trying to be helpful.
    OP, I hope you got this figured out. I haven't seen a response.
  • My unit is 50amp 2007 Fleetwood Revolution and is plugged into 30 amp when stored in three sided car port. I have gone out and hear just a clicking noise. Genset appears that the generator was trying to start. I hit stop and it ceases. It happened several times last winter and then it quit doing it. A week ago it did it once and Has not repeated since. The generator works fine when I start it manually.
    I can't stand it.
    Am scheduled for visit to Newmar in December, have put it on the list for them to check out. Thanks for the insight. Hope it not a setting i'm missing. Never had this problem with any of my previous Newmars !
  • I have a new Entegra Emblem that came with a Magnum AGS. It is what I now call the "Zombie Generator Start" because it kept starting the generator when stored no matter what I did. Had it not enabled, had all the switches (battery voltage, interior temp, etc.) set to off. I had the coach battery disconnect disconnected but it didn't matter. I'd come back after a day and it would be running. So I finally removed all the wires from it until I could get it in to service. They tried everything to convince themselves that I wasn't crazy or stupid and ultimately were told by Magnum that it was a defective unit so I got it replaced. If you google it some you will see that there are some units that are zombie units. Not sure how common but it drove me crazy...
