Gundog
Nov 15, 2018Explorer II
Tom/Barb wrote:
What fluid is in the transmission from the factory?
Mine had a sticker that said Transynd you need to know because when you drain it you don't get it all out and you are not supposed to mix fluid types. Look around your engine bay and see if it tells you. You may also be able to find out through a dealer for your chassis with your VIN number. Mine had the sticker in the access panel where you would add the fluid.
