Executive45
Nov 16, 2018Explorer III
Gundog wrote:wolfe10 wrote:Gundog wrote:
This is the oil pan I bought for doing my oil changes. A standard oil drain pan won't hold 19 quarts. They make this same one with a pump to pump out the waist oil but I have a forklift so for me I just lift the pan higher than the container I am draining it into and open the valve.
Oil drain pan
I just use the same old Rubbermade bucket I use for oil changes. Line with black HD trash bags for easy clean up. Use an old coffee can and funnel to transfer oil fluid to pail when finished. With a pail you have one quart left over-- I usually just ask the service department at the Allison dealer for an empty Transynd gallon jug and pour off the quart before I put the new fluid in the transmission.
All the mechanic work I have done over the years I wish I had bought this pan years ago. I like the expanded metal grate it has makes it easy to drain oil filters and I can't drop the oil plug in the bottom of the pan. The wheels keep me from sloshing the oil out when getting the pan out from under the vehicle. Now I just have to remember not to run over it.
And the money you save by doing it yourself will pay for the drain pan...:)...Dennis
