Deano56 wrote:
I'm not throwing them out and putting new coils in, if I was doing that I would be asking how to change them. As for raising the front end appreciably, they did just fine until they started leaking. Most post is hav seen you cut the bag out with a sawzall, don't see how a hole would work
Right up through the hole in the bottom with the proper size and you should end up with a lot of pieces to extract with a pair of needle nose or other.
You might do a search for all the people who have done so in their posts and then send them an IM for the particulars.
