harold1946 wrote:
I remove them by using a 1-1/2" hole saw without the drill. Lubricate the bag and grasp the bag with locking pliers and pull the bag out.
Fold the new bag to look like a hotdog bun and secure with wire ties. insert the bag, cutting the ties as you go. Insert the cap through the coils before the bag is all the way in.
With the suspension fully extended fill the bags to 100-110 lbs. That will allow the bag to fully expand. Lower the coach and adjust the pressure to the desired amount. Check the ride hight.
if you dont mind, would you explain the holesaw part, I'm not visualizing that part
