K_Charles
Jul 16, 2015Explorer
If the proportioning valve is hooked to the rear axle you don't want to use air bags because when you lift the body up away from the rear axle it limits the rear braking. Look and see if the brake line to the rear end goes thru a valve on the frame that has a lever going to the rear end.
