Gator48
Jul 12, 2015Explorer
Air brakes
We are in our 3rd year of ownership and traveling in our 2006 Itasca Horizon. Retired last year and now have the time for the longer trips. I always like to have a lot of stopping room so everythi...
mabynack wrote:
Pumping air brakes is NOT recommended because every time you pump them you use up some of the air reserve. Pump them too many times and your brakes will lock up. You should apply them with smooth, steady pressure.
You should have your brakes checked if they aren't working correctly. They may need an adjustment or you may have a weak air line.
