moparmaga2
Jun 16, 2013Explorer
wa8yxm wrote:
Some generic comments on air compressors
If your RV has air brakes and thus an on board compressor.. That's all you need, just get the proper hose and fittings.
Again, as has been stated on this thread, the on-board compressor will not work for the mid to heavy weight diesel pushers. For our purposes, we will define Mid Weight as GVWR 35,000 lbs + up to 60,000 lbs heavyweight.
The on board compressor on a diesel pusher WILL NOT work for more than 100 PSI easily. Most mid to heavy weight diesel pushers call for 120-125 PSI in the front tires. Being low on air 20-25 PSI is very significant, as most times the two front tires are at their maximum weight capacity with full air PSI in the tire.
We have many discussions on this site about how a toad brake system may net you two extra feet stopping distance on these big mid to heavyweight Diesels making you "safer" :R, but for any fellow diesel pusher owners, PLEASE put that 120-125 PSI in your front tires. If your Front Tire blows out due to being underinflated or overloaded at 70 MPH, you most likely screwed and there will probably be a REAL safety issue!
38,782 PostsLatest Activity: Sep 02, 2026
