joema62's avatar
joema62
air compressor for inflating tires
VIAIR VIAIR-40046 400P-RV VIAIR Portable I have identified this air compressor as a potential candidate for our integra rv. Have not found specification on its air capacity and pressure ability. Is there anyone that help
  • Go to the viair web site they have all the specs. I have the Viair 450p. Mine is the auto model. Great air compressor. When comparing compressors you need to compare pressure and cfm. The cheap ones just don't cut it. I use it to winterize on the road when temp drops below 10 degrees. Plus using it on tires. Check out Amazon prices.
  • Can you not use the on board air system to inflate your tires?
