5thhand's avatar
5thhand
Air compressors
What type of air compressor do I need to get 110 PSI quickly? It takes forever on my current 4 gallon 135 PSI Craftsman. What is the best bang for the bucks?
  • Probably need smaller compressor to haul with. Concerned whether it can top off 90-100 PSI,
    Also looking for moderately priced garage version.
  • Problem is getting it to the 110psi. Once it nears the tank pressure it goes pretty slow. You would want at least 135psi with a big CFM compressor.
    I got my air horn kit from Amazon. It came with a 2 1/2 gallon 135 psi 12V compressor but the cfm is low. I also plumbed in another 2 1/2 gallon 110V compressor, but I don’t know it’s cfm. I keep my tires at 95 rear and 80 front. It works ok.
    I can't say this is the fastest, but at over 1000cfm @ 350psi, this would be pretty quick:
    But someone will probably have more practical suggestions if you give a few more details - are you looking for something small and 12V powered that you can carry around in the RV and use anywhere? Do you just want something to keep in your garage at home? Do you want an oil-free compressor with an air regulator so you can use it to blow out the water lines for winterizing?
