jeromep
Dec 17, 2021Explorer II
wa8yxm wrote:
One final note:
As my RV tech says Colemans Suck, others blow
What this means is that the Coleman sucks air in through the condenser and blows it out the sides.. Others do it the other way around blowing air through the condenser.
Why is this important.
Cleaning coleman.. Remove 4 bolts, lift lid, peal crud off condenser, Replace lid (Cowel) and 4 screws.. Finished.
Others
Remove outer cover (Cowel) often 10-12 screws
Remove INNER cover (Not always easy)
If you have large hands remove fan
Now you can clean the condenser.
I knew there was a reason I liked the Colman units better than the others. This is a very logical way to make a packaged A/C, whether it RV rooftop or any other configuration.
38,782 PostsLatest Activity: Sep 10, 2026
