Gene_in_NE
Jul 05, 2013Explorer III
Chuck Goodwin wrote:No doubt you already know this, but an air conditioner removes or condenses moisture from the air as it conditions it. The moisture is water or condensate. If your rig is perfectly level, the water can pond around the seal between the air conditioner and your roof top. If the seal is not perfect or has loosened as mentioned by "Dick_B", water will drip on through. :)
Well, with this heat and humidity am sure we all are using our ACs. Ours in our '04 Excel TS has started to drip. It's a Dometic DuoTherm 600 Series Penguin....Thanks!
Chuck
