onthebus's avatar
onthebus
Air Conditioner from engine
I have a National RV Sea view with a ford triton 10 engine. the air conditioner is not working. The fan runs but there are two problems. There is a valve that directs air to defrost or cabin and the valve will not change air flow direction. The fan runs and the air is not cooled. Seems like a relay problem but I don't know how to analyze or maybe it's something else entirely. Thanks for any help you can give.
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    The Valve,you mentioned, is called an Air Dam or Air door. is likely operated by ending vacuum and a vacuum motor.
    If there is no vacuum the system defaults to DEFROST so check for air out the defrost vents.
    Causes of no vacuum and I've see all these over 50 years of cars
    Broken vacuum hose
    Hose off fitting
    Connector off valve
    And the one that really got me was a cruse control solenoid (Also a vacuum device) which got religion.. Yup. it was HOLEy.
  • Thanks for the analysis. I'll check out hose leak and move on from there.
  • As above, vacuum drives the air controls, but with some models, loss of refrigerant can also cause the default to defrost.
    A bad compressor or clutch as well as a holed line or evaporator would all be suspects.
    Can you see the compressor? Is the clutch engaging? If so, have you tried adding a can of refrigerant?
  • DrewE's avatar
    DrewE
    Explorer III
    Offhad I suspect a vacuum system problem; if memory serves, the controls for the heater and air conditioner are vacuum actuated on the chassis. I'd hunt for a bad hose or a cracked or otherwise compromised accumulator for the HVAC controls. It may well be buried someplace not too accessible behind the dashboard.
  • All the doors that direct the air flow run by vacuum and default to defrost when vacuum is lost.
