hriesExplorerFeb 17, 2018Air DumpHello All, I need some help. I have a 2004 HR endeavor. The air dump doesn't work. It used to work. It did have a blown fuse.So I replaced that and it still isn't working. It hasn't blown since I pu...Show More
ILVMYGTExplorerFeb 17, 2018I had that problem. They tied the grounds for the solenoid together and the ground was loose. I tighten the ground and it solved the problem.
Related ContentDump Station near Ft Myers FLAir Dump Valve issuesAir Conditioner vibrationAir dump.Dumping air when parked
