farmingdad's avatar
farmingdad
Air filters
Airconditioner blowing wam air in my tiffin zepher on 2 of them just 1 working right were are the filter for them. I am in process of buying it I don't think filter been cleaned but can't find them
  • I don't remove mine, I just use a small vacuum to clean the filters, works great and saves time.
  • Not sure what year your Zephyr is but most Tiffins have ducted A/Cs and the intake filters are located in the ceiling intake ports. The ones on the driver's side are intake and the ones on the passenger side are the output of the A/Cs. You just pull straight down on the port louvers to access the foam filters. It doesn't sound like filters are your problem though - more likely the starting capacitors on the units.
  • Taking for granted you have the standard type AC. When standing under the AC if you look up at the plastic grill work the filters are behind that. There should be some sort of tab to releace the grill, once removed the filter will come with the grill remove filter wash dry and replace. However I doubt if the filters are the cause for the units not cooling. Sound like more involved than filters.
