wny_pat1
Oct 07, 2013Explorer
JetAonly wrote:And it can be white also. Mine are white. Green or White are both accepted as industry standard for the rear.
Pardon me for being dense, but Ivylog's link says rear is green.
JetAonly wrote:That is correct. And most importantly, you have to make sure you are looking at a schematic for a truck or motorhome, and not one for a road tractor. The road tractor is set up differently. I've always called them "Maxi brakes" but the proper name is spring brakes.
FWIW, if I read the diagram correctly. it looks like either system below set point will trigger the spring brakes.
38,769 PostsLatest Activity: Dec 31, 2014
