holstein13
Dec 03, 2015Explorer II
11178adm wrote:Warning: if you mess this up, you could damage your air system which controls all your brakes and die in a cataclysmic inferno on the highway. YMMV.
if you cant find it it is fairly easy to install one find your dry air tank
the wet tank is the one the air from the air comp or air dryer goes to first
the dry tank feeds from the wet tank find a plug that is does not have a fitting in it preferably one not on the bottom of the tank drain the air system before removing the plug install a female quick coupler, use either Teflon tape or liquid pipe sealer on the fittings if needed for access you can install a hose and route it for convenient access and to avoid chaffing the easiest hose to work with would be plastic air line and should be available at any heavy truck dealer or fleet supply store if you need to get new hose you will need enough male and female couplers for the tank, hose and the air chuck also make sure the hose is long enough to reach the tires furthest from the connection
