Ranger_Smith
Sep 19, 2015Explorer
When you run the engine do you have any air at the drain laynards? Do you hear any air leaks with it running? Start it up and see if any pressure is being made or hear any leaking? Is the suspension up or did that drop too? Usually when you loose pressure the brakes will lock up. Did the brakes lock up??
38,780 PostsLatest Activity: Nov 24, 2017
