bluwtr49
May 09, 2016Explorer II
Another thought is that you adjust the tag axle to remove some weight from the front axle. I adjust mine so that the drive tires run at 95 psig and the front at 105 psig. Those pressures are 5 psig above what was calculated by axle wt. The fact that you need 117 in the front and only 85 in the rear suggests you have a lot of wiggle room in moving some weight rearward.
38,776 PostsLatest Activity: May 15, 2026
