wa8yxm
May 12, 2016Explorer III
I would say scale the RV, 4 corner weight, and adjust COLD pressure per the tire maker's chart (add 5 PSI if you like) It is possible the front tires are a bit "low" for the weight they are carrying.. Also possible you need to repack the bearings if they are not wet bath, or refill if they are Plus you might have a brake dragging. You do keep your foot OFF the brake pedal except when needed, right (some folks were taught to keep left foot on the brake to inprove response time in a panic situtation, I was taught to drive a stick and have better things to do with my left foot).
38,776 PostsLatest Activity: May 15, 2026
