Mr_Mark1
May 12, 2016Explorer
wolfe10 wrote:becker wrote:
My inside duals tend to run 5 to 10 hotter than the outsides (I don't know why)
FYI....
Less air flow to the inners, so less cooling.
Mr. Becker,
We ran the same pressures in our Dynasty (miss her). I was always told that (as Mr. Wolfe10 states), less air flow and the inner tires are closer to the engine/transmission which will heat up the tires.
Our current coach with 365's on the front and tag, 315's on the drive.
Our pressures..
Front 108 (105 suggested)
Drive 105 (100 suggested)
Tag 100 (85 suggested)
On hot days, we have run temps close to 140 degrees. The pressures seem to go up about 3-5 lbs.
MM.
38,776 PostsLatest Activity: May 15, 2026
