Executive45
Mar 17, 2019Explorer III
Be careful changing that solenoid. Removing that 1/4 air line lets your coach drop like a rock. Only change it from above unless you block your coach. It's easy to reach through the generator compartment. I was shocked at how fast the coach dropped when I changed mine. You do know there are two switches that control that cover, yes? One on the driver's side which is the main and one on the passenger's side that is the slave. Driver's side must be ON for the passenger side to function. Check both for loose/broken wires.....Dennis
