mexicanpiloto13
Mar 17, 2019Explorer III
Thanks for the info. I tested the voltage on the two wires going to the air step solenoid yesterday and didn't get anything. Can't figure out why. I tried testing voltage with the ignition on and off, also we have two toggle switches in he coach to extend the floor and I put those in different positions as well and re-tested. Seems it should have 12 volts going to the part. The part says 12 volt and also 2.4 watts. Any ideas on when those wires should have current? What's strange is that the part seems to have broken just sitting there (I am use to RV's breaking like that!) I slid the RV out of our RV garage, lubricated the underside, then when I went to put it back in the step floor had extended. I checked to make sure I didn't pull a wire loose underneath and all looked normal.
