First several questions...do you have hydraulic stabilizer jacks or an air leveling system or both? Second, when parking, are you using two feet to move the coach? One on the go pedal and one on the whoa pedal?
When first starting the coach, turn the key and start it. Then turn on the Cruise Control. Press the Set button on the steering wheel. This will increase the idle to about 1500-1800 RPM. As the air pressure builds you'll see the increase on your gauges. When the pressure reaches 115-120 you'll hear the pressure relief valve expel. If you have an air leveling system, press the "Travel" button. Watch your gauges, they should drop to about 95psi or so and then begin to build again as your air bags inflate. Once the travel light turns green and you hear the pressure relief valve expel again, you're ready to travel.
Monaco recommends you have a fully aired coach before deploying or retracting the slides.
If you're using the air levelers, they will automatically dump the air and level the coach. After about 30 mins the computer will reactivate and relevel, dumping any excess air. Leave it on automatic. It knows what to do.
Your air brakes have no effect on your leveling. You will have two ride height valves, one in the front and one in the rear. You might want to have both checked if you think they're not operating properly.
I recommend you read up on the air system on your coach. There are certain checks you should do before moving your coach. The more you know about the function of your air system, the safer you'll be as a driver. Many States require you to pass an air system check before issuing a license. I think it should be mandatory in all 50 States...but that's just me.
Finally, while it's an old military video, (1967), it's very informative....Click
HERE....enjoy your new rig....Dennis
