Bordercollie
Jan 06, 2016Explorer
If you have Tire Man or Borg or other long solid metal custom formed valve bodies installed on all of your wheels it will be quick and easy to add or adjust air pressure with any kind of air chuck and beauty disks in place. As said above, it takes some time and technique to fill a tire to 80 psi with a 120lb rated compressor. Let the pressure build up to over 100 psi before attempting to add air. Gas station air hoses are often not able to fill RV tires to 80 psi or are set for car tires at 32 psi. Many of us use 65 psi in front tires and 75psi in the rear duals.
38,763 PostsLatest Activity: Dec 05, 2025
