JimR 1 wrote:
dougrainer wrote:
The outside Condenser coils you can access from the outside with a Garden Hose. The INSIDE Evap coils are harder to get at. Remove the AC filter under the rear bed and see if you can access the Evap there. Are you asking because you have a cooling problem? Doug
I do not remember any ALFA having a filter under the bed as that is where the engine is.
JimR
One of the reasons Alfa went out of business was because the DESIGN of the basement AC system meant that you had inadequate return air from the middle to front of the Motorhomes. WE sold Alfa for just 1 year and dropped the line after numerous Customer complaints of NOT getting the Alfa's below 80 degrees on higher than 90 degree days. This was a known problem to Alfa and Alfa could never engineer a fix. So, the Air filter on the units we sold was indeed in the back under the bed. Doug
