Dannydperez's avatar
Dannydperez
Alfa basement air service
Hello everyone! I’m new to the forum, and looking forward to sharing my experiences with the forum, as well as looking for some guidance! I have a question about servicing my basement air unit. Is there any way to clean the coils on the unit without removing it? Maybe cut a hole something make a service hatch?? Thanks in advance!
  • Anonymous's avatar
    Anonymous
    Approved
    dougrainer wrote:
    The outside Condenser coils you can access from the outside with a Garden Hose. The INSIDE Evap coils are harder to get at. Remove the AC filter under the rear bed and see if you can access the Evap there. Are you asking because you have a cooling problem? Doug
    I do not remember any ALFA having a filter under the bed as that is where the engine is.
    JimR
    Anonymous
    Approved
    To do the best job the unit should be removed and cleaned and serviced. There are some shops that can do that very well.
    See my PM
    JimR
  • The outside Condenser coils you can access from the outside with a Garden Hose. The INSIDE Evap coils are harder to get at. Remove the AC filter under the rear bed and see if you can access the Evap there. Are you asking because you have a cooling problem? Doug
  • Make and model would help. Most are already incased and just cutting a hole will not let you do a good job cleaning. call a friend who use to own one and he said to you Good Luck. He stated his comes out the bottom of the RV. It was made by coleman who no longer makes them. It has two compressors. As stated its a case inside a case. here is a picture maybe of what you have.
    https://www.pplmotorhomes.com/parts/rv-appliances/air-conditioner/air-conditioners-coleman-dometic/coleman-mach-2-ton-plus-basement-ac-he-w-heat-pump_69859
