Cbones wrote:
steveownby wrote:
Cbones wrote:
Just curious if anyone has had an Allison 3000MH fluid and filter change with TES295 recently? I was quoted $875 for changing both filters and draining/refilling with TES295. I already have the TES295 in it so it's not a flush or anything special, just a simple change. I think that seems excessive. That was at a local Allison service center, who claims that they have never done a motorhome tranny fluid change. I have 90K miles on a 4 yo coach, and according to Allison's site I am due for a service, even though the service indicator says oil life 78%. Tranman says just run an oil analysi and look for any issues before changing, but I feel that I would rather just change the fluid so as to not have to worry about it. Any suggestions?
With a 4 year old coach and 90k on the clock, I would pull a sample and send it here:
http://www.jglubricantservices.com/online_store.html
If it tests ok, then change the filters and top up with fresh fluid. Then test fluid annually and change filters in 3 more years. The Allison recommendation is 36 months on filters and 48 months on the fluid or test.
The Allison OEM filters should be about $50 for the 2 filter kit. The Transynd is about $40-42/gal. The sample test kit is about $25.
On the IRV2 Allison Forum, the retired Allison engineer who wrote the TES295 spec authored a thread and he will answer questions and interpret test results. His name is Tom Johnson.
Steve,
Thanks for the reply. I have already been in touch with Tom. I mistakenly referred to him as "Tranman". How much fluid do you wind up losing with just a filter change? I was under the impression that it was almost 2 gals, so I figured it really wasn't too much more to just change all the fluid and not have to worry about it for a while.
I don't have actual experience with the 3000. My transmission is the 4000 which takes about 10 gal for a change and does take about 2 gal for the top off. The filter kit for both transmissions are the same but I was under the impression that the fluid loss on a filter change was less than one gal on the 3000.
