rgatijnet1
May 03, 2014Explorer III
Knowing the temperature does not help too much unless you know whether the temperature sensor is at the output of the torque converter(hottest point) or just reading the temperature in the fluid sump(coolest). The higher the temperature in the torque converter the sooner that you must change the fluid to prevent damage.
38,782 PostsLatest Activity: Sep 10, 2026
