Srtinc
Jul 21, 2015Explorer
My Allison shift selector shows the "cat eye" symbol when I turn on the key to start the coach. The selector will not switch to "N" neutral and The engine will not start because the Allison ECU is telling the main ECU that the transmission is in "R" Reverse or "D" drive.
I may have a bad ECU or a loose or bad connection, but I need to locate the module to find out.
38,778 PostsLatest Activity: Jun 05, 2026
