Corkey05 wrote:
gutfelt wrote:
Corkey05 wrote:
The Allison transmission defaults to neutral at 11 volts. It could be in the charging system, and a low battery. A quick jumper from the house batteries (if at full charge) to chassis batteries, would discount that issue.
Not Low voltage at all as OP says it goes into reverse
as two others have said sounds like the rear Brakes are stuck on
I have had that happen
Maybe the OP said it goes into reverse, but the thread title is "Allison will not go in gear". The post is confusing to begin with, but voltage is often overlooked so I mentioned it ... no need to discount any possibility.
Can't include all the details in the title, that's why you read the thread. Low voltage is being discounted because it goes in gear, that's how you eliminate things and get to the problem.
