Ava
Oct 15, 2017Explorer
I just replaced the throttle position sensor on my MD 3060. The problem started with hard downshifting which was fixed by adjusting the tps cable. The cable eventually broke after going over a big bump and the tps tells the transmission you are at wide open throttle. I had to turn off my pac brake to get it shifting again. The tps may need some attention. Hope that might help.
38,769 PostsLatest Activity: Jun 25, 2013
