mda
Aug 28, 2013Explorer
Measure the voltage of your alternator at your chassis battery while the engine is running. It should register 13.5-14.7. Now measure the voltage at your house battery. The voltage should be identical or very close. If not, it is probably the isolator solenoid, or B.I.R.D that is faulty. If the house battery does not take or hold a charge after driving a long distance, it is probably bad. You should have the battery tested.
