theoldwizard1
Nov 12, 2020Explorer II
Floridastorm wrote:
Does anyone know the manufacturers that use this process on their motorhomes? From my understanding it is the best manufacturing process to ward against leaks and water damage.
Water damage typically comes from leak in the roof or windows and doors. The seam between the roof and the wall is a common area for leaks.
No wall construction technique will solve this issue, but building the wall with composite sheathing like Azdel will prevent rot.
Of course, all manufactures use plywood for sub-flooring and if it gets wet enough, it will rot. It will NOT prevent delamination.
(Several manufactures tried composite sub-floors a few years back. They flexed to much for most customers because the did not add additional cross bracing.)
38,782 PostsLatest Activity: Aug 23, 2026
