rexlion
Nov 12, 2020Explorer
ron.dittmer wrote:That one photo indicates “moisture proof plywood.” Is there such a thing? Moisture resistant, I could understand, but moisture proof? Call me a skeptic....
Our 2007 Phoenix Cruiser is made as follows.
Floor - Marine plywood deck, rectangular steel floor framing, foam block insulation, durable corrugated plastic under-barrier.
Walls - Gel-coat fiberglass exterior, aluminum studs, foam block insulation, walls rest on the floor (not bolted against the floor).
Cut-outs - Framed as shown, foam block insulation, finished with wall-papered luan interior wall panel.
Roof - (see picture above) Curved aluminum rafters for a domed roof, luan inside and outside, inside finished with a fabric, outside covered with sheet fiberglass.
I suppose there are better materials and methods, but ours has been working well.
There are so many more interesting details how a Phoenix Cruiser is constructed. CLICK HERE to watch a YouTube slide show that points out some unique detail.
38,782 PostsLatest Activity: Aug 23, 2026
