j-d
Jun 20, 2014Explorer II
The E450 chassis needs 80-PSI in all four rear tires to support the 9500-LB rating of the rear axle. Rating of any wheel shipped with an E450 should be no lower than 80-PSI. Tire pressure needed to support the 5000-LB FRONT Axle rating is around 65. Because of the rear axle rating, the tires need to be Load Range "E".
