EMD360
Aug 30, 2015Explorer
I just have to add that I hooked up the water, filled the hot water heater and tried the hot water taps and THEY DIDN'T WORK!
I was trying to figure out what I did wrong, could I have a valve in backwards? So the in valve was working just fine, the water heater filled with water.
I just let out part of the water with the pressure relief valve and then undid the top valve. A small piece of the broken valve had fallen into the water heater and when I refilled the heater, the piece got lodged in the upper valve! So I removed it and reconnected and finally the problem was fixed.
Just thought it was another typical fix. If at first you don't succeed...
