McGoo's avatar
McGoo
Amish fridge goes into dumpster!
Well the Amish fridge is going into the dumpster and being replaced at Red Bay. If you should be unfortunate enough to have one, don’t count on the warranty being honored. When I wanted it repaired or replaced, I was told to jump thru many hoops. I had a repairman on site at the time and he could not find a problem other than the fact it was not getting cold enough. I installed two fans outside to force more air thru the outside vent to no avail. Now after two years of not doing the job, (just sat the past four days waiting for the new one and the temp is 50’ and 27’ for high low temp). I believe it is time to let folks know it was junk as well as the dealers word (you know who that is since there is only one dealer). So much for Amish craftsmanship!
I also contacted my repair service in Phoenix that installed the unit too see if they could help. He said they had installed several more and there were so many problems, they refuse to install any more. He also mentioned that the Amish were not supposed to use machines and didn't know how they were able to charge them properly.
Tried to send them a copy of this post but their email didn't work.
