- RobertRyanExplorer
That is not a big deal with Cabovers or Pusher Class A Motorhomes it is the other aspects of the design that is appealing. Try working on a modern vehicles engine[emoticon]
[emoticon]
As you have never seen a Cabover Motorhome based on a Japanese or European Light to HeavyTruck chassis. I think I would definitely need a new thread explaining - Grit_dogTrailblazer
RobertRyan wrote:
Didn't say they needed "more" maintenance...just that a cab over that can flip up out of the way makes maintenance much easier as you can walk up and stand next to the engine.
Grew up with vans and it was a pain getting to much of the engine.
That is not a big deal with Cabovers or Pusher Class A Motorhomes it is the other aspects of the design that is appealing. Try working on a modern vehicles engine:(
:h - RobertRyanExplorer
That is not a big deal with Cabovers or Pusher Class A Motorhomes it is the other aspects of the design that is appealing. Try working on a modern vehicles engine:( - valhalla360Navigator
RobertRyan wrote:
Ruins one of the big advantages of a cab over design where you can move the cab completely clear to get great access standing next to the engine.
No Off Road Cabover Motorhomes which need more maintenance than any other Motorhome, have only a portal. Pusher Class A's have similar access.
Grew up with vans and it was a pain getting to much of the engine. - RobertRyanExplorer
In this case an Off Road Bus
RobertRyan wrote:
valhalla360 wrote:
Class C uses an existing front truck body (typically from a van) with the house custom made by the MH manufacturer.
Class A the MH manufacturer builds both the house and the cockpit enclosure all as one structure.
Looks like this one uses a cabover truck retaining the cab, so it would technically be a Class C. I assume the cab can't flip forward for easy engine access based on the pictures.
No engine access is in a portal section in the Cab like other Cabover Motorhomes
Ruins one of the big advantages of a cab over design where you can move the cab completely clear to get great access standing next to the engine. - RobertRyanExplorer
No engine access is in a portal section in the Cab like other Cabover Motorhomes - valhalla360NavigatorClass C uses an existing front truck body (typically from a van) with the house custom made by the MH manufacturer.
Looks like this one uses a cabover truck retaining the cab, so it would technically be a Class C. I assume the cab can't flip forward for easy engine access based on the pictures. - RobertRyanExplorer
RobertRyan wrote:
As well we have the new Super C Motorhome from STG Global
Plus Off Road Class C's from the likes of SLR Motorhomes and other manufacturers
- RobertRyanExplorerAs well we have the new Super C Motorhome d e im STG Global
38,782 PostsLatest Activity: Sep 02, 2026
