newman_fulltime
Aug 13, 2014Explorer II
if you have access under where the heater is you can drill and replace the feet with nuts and bolts then in the back use a couple conduit clamps around the back frame.to holdthe door closedi made a swing arm on the non hing front foot and a l bracket i slide in the top use a bungie chord
38,782 PostsLatest Activity: Sep 10, 2026
