Executive45
Aug 14, 2014Explorer III
Here is the clicky for my blog:
Samsung Install
Here are some close ups...hope this helps....Dennis
This is one of the leveling legs. I used these legs to level the fridge, shimmed up the wheels, then removed them. The "L" faces forward.
I purchased a Simpson Strong Tie from Home Depot. Bent them accordingly, drilled them using the above leveler as a template and installed it backwards.
I then ran a bolt through the plywood base and secured it with a washer and lock nut.
Probably overkill but for added security, I used a 3" 1/4" lag bolt and washer thru the rear panel and into the plywood base.
Finally, three bungee cords ensure the doors will not open while traveling.
Samsung Install
38,782 PostsLatest Activity: Sep 10, 2026
