Gator48
Aug 17, 2014Explorer
PCM1959 and Craig P
I also added 1/4 inch shims under the rear wheels to level it up. It's almost good to go enough that I am not pulling it out to add more.
I removed the front screw legs and fashioned a "Z shaped bracket that is lag screwed to the plywood floor and then bolted to the brackets that the screw legs were originlly mounted to.
I also re-installed a full width bracket that was fastened to the back top edge of the Norcold with about 10 small screws to the Samsung and it is bolted to a 2 X 4 brace fastened to the side wall of the coach. This keeps the Samsung from tipping. We just returned from a week in the mountains in NC and all held up real well.
38,782 PostsLatest Activity: Sep 10, 2026
