Dale_Traveling
Dec 24, 2013Explorer II
rgatijnet1 wrote:That would be my first change. Add 10 PSI and see what happens. Doesn't cost anything. Also try rotating them front to back first then left to right before spending money. Check the tires first to ensure they are all position type and not steer or drive only. A left to right rotation will change the direction of travel so check to see if the tires are unidirectional rotation also.
You may try inflating them to the maximum load tire pressure and see if that makes a difference.
38,769 PostsLatest Activity: Apr 03, 2026
